- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Create DHCP Pool on a Local Lan configuration on Meraki MX
Hello Team,
I'm wondering if how can I create a DHCP Pool on a Local Lan Subnet (192.168.0.0/16.)
I want to create a DHCP Pool for 192.168.10.0/24 subnet and 192.168.20.0/24 subnet.
I know it cat be achieved using VLANs but their current setup is their using the whole 192.168.0.0/16.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you just need a bigger DHCP scope why not use 192.168.10.0/23? Very simple then.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You should still be fine to create the VLANs as long as DHCP isn't running for the whole 192.168.0.0/16 subnet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello ,
I am avoiding to use VLAN as they do not want to put up a Segmentation and do not want to have any changes on their core switch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello sir, what i need to to is to create a dhcp pool without creating vlans which is not possible in MX. I think i will be advising them to use VLANs as it is the best practice.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I just wanted to add. If you're setting all MX ports to access mode on a specific VLAN, nobody knows you're using VLANs. The VLAN ids will never exit the MX when configured like that.
