Content Filtering in Z1
MrUn1x
Hey
Is there any work around for Z1 devices for content filtering ?
Best Regards
4 REPLIES 4
MerakiDave
The Z1 appliances only run the Enterprise license, they cannot run the Advanced Security license that has the full web content filtering you might be asking about, on the Z1 you basically just have the firewall page for L3-L7 rules.
MrUn1x
Yea am aware about the license , when i use L7 firewall its block interal access for services in the network too not only over internet .
Thanks for your fast response .
I would double check the firewall rule configuration and make sure you have the appropriate permit rules in place, for example if you have multiple VLANs and the MX will be providing the interVLAN routing and you want to allow such LAN-to-LAN traffic.  Let me know if I misunderstood.
MrUn1x
Yes , Correct
