Communication between Client VPN and IPSec peer subnet
Hello everyone,
I am not sure if this is possible or not. Please guide me either way.
Current scenario:
We have a Meraki MX65 and have configured the following.
1. A site to site vpn with peer local subnet 172.16.1.0/24. (Subnet type IPSec Peer)
2. A SSL client vpn for remote access to the MX65 with subnet 192.168.100.0/24.( Subnet Type Client VPN)
3. Local LAN with subnet 192.168.200.0/24 ( Subnet Type Local VLAN)
What is working:
1. Local VLAN and IPsec Peer can communicate.
2. User can connect to SSL VPN and access Local VLAN
What I want to achieve:
1. User to connect to SSL VPN i.e Client VPN subnet (192.168.100.0/24) and be able to access the resources located in IPSec peer subnet(172.16.1.0/24).
I hope I am clear enough.
Thank you for all your help and suggestions in advance, Experts.
Regards,
Aashu
Accepted Solutions
Re: Communication between Client VPN and IPSec peer subnet
Go to the Site to Site page, and ensure that your client VPN subnet is participating in the site-to-site VPN. 🙂
2 REPLIES 2
Hi @Nash ,
Thank you for your quick reply and apologies for getting back here little late. 🙃
Yes you were right I had to make sure that client VPN subnet was selected to participate in site to site VPN.
I also had to make changes on other end of tunnel to allow that particular subnet on site to site VPN.
This issue has been resolved.
Thank you for your help.
