Yes, this is exactly what you need to do:
The Edge router is configured with PPTP on the WAN side and with an IP from the /28 on the LAN side. All your MX and other routers get an IP from the /28 block and use the Edge-Router LAN IP as the default gateway.
The EdgeRouter should not do any NAT, just routing.
