Client VPN with cisco anyconnect authentication
nikmagashi
I am trying to configure the cisco anyconnect authentication with meraki MX but I am having some problems. I have configured the Anyconnect Settings but I am geting this error when trying to connect via anyconnect:
10:17:23 Connection attempt has failed.
10:17:24 No valid certificates available for authentication.
10:17:24 Connection attempt has failed.
The Certificate Authentication is disabled on the meraki settings for Anyconnect. I dont see any other settings with certificates references on meraki Client VPN which I can try and change.
Has anyone been through this before or has any suggestion?
The only option available is to disable certificate authentication. If you've already done this, then I suggest opening a case with Meraki's support.
Try disable It:
Also, check the following patch C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client and edit the archive preferences_global.xml and try to find some lines about the Certificate.
