We currently have a client VPN setup for Active Directory authentication. Is it possible to use Azure AD authentication?
Thanks,
Derek
Hi @Derekjr , I believe this is only possible if you have an on-prem AD sync’d out with your Azure AD. Point your vpn clients at the on-prem.
We do have on-prem AD but we are moving all of our users to Azure AD so they will be cloud only.
@Derekjr : May be the below thread helps
https://community.meraki.com/t5/Security-SD-WAN/Meraki-VPN-Client-Azure-MFA/m-p/48322#M12189
What about using Meraki cloud Authentication. How does that work?
@Inderdeep Do you have any recommendations on how I could keep the VPN using AD Authentication and use the cloud authentication?
i don't want to disrupt my ad users VPN connection.
