Client VPN timeout
LRH
Client VPN timeout
How can I automatically disconnect a client vpn session once it reaches 30 minutes of inactivity?
I would like for the connection to get dropped and on the client side it makes them reconnect.
2 Replies 2
You can't.
Chingwongfu
You can. In Windows you have to go to network connections and change the setting for idle timeout. The only way to "enforce" this is probably if the client is in an Active Directory environment or such where you can control the privileges/policies.
Control Panel\Network and Internet\Network Connections > select the VPN connection > check Properties > Options tab > "Idle time before hanging up"
