Client VPN timeout on mac
jay_b
Hi all,
Just wondering is there any way to configure VPN timeout on macbooks ? As Meraki doesn't have that option we have to configure on endpoints 😕 I tried play with racoon.conf but didn't get any success.
7 Replies 7
Have you checked this link?
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration#macOS
jay_b
Actually this looks like from old macos. I don't see this option in newer macos.
https://support.apple.com/en-ca/guide/mac-help/mh119412/mac
Ok, but It's a native client on macOS, you should have to open a ticket with Apple.
jay_b
@alemabrahao  Thanks for your help
Do you have a lock at the bottom left of the Network pane?
If there’s a lock at the bottom left of the Network pane, click it to unlock the preference pane.
Hello @alemabrahao  I tried that but no luck there as well.
GStone
Are you doing this from the local Mac or do you utilize anything for MDM?
