Client VPN slow
Duoc
Client VPN slow
I've setup Client VPN through our MX250. While it connects just fine, the speeds I get are hovering around 1.5Mbps up and down. The only configuration I've done is to put VPN clients on a different subnet.
The MX250 has a 1Gbps connection, so I'd expect much faster throughput. Any advice?
Thanks,
Duoc
3 REPLIES 3
If the remote user is on a assymetric circuit you find be having troubles with re-transmissions.  Try enable timestamping on the Windows TCP stack with:
netsh int tcp set global timestamps=enable
Duoc
Anybody know if the fix mentioned in the reddit thread has made its way to beta? I updated our MX250 to the latest available beta firmware and am still seeing low throughput.
