Client VPN routing on MX
Is the MX client VPN limited to local subnets or can resources in other MX sts vpn subnets be accessed?
Accepted Solutions
Re: Client VPN routing on MX
Hi @OSPF71,
If you go to Security Appliance/Teleworker Gateway > Configure > Site-to-Site VPN, there is a section called VPN settings. As long as the vLAN is set to yes in the Use VPN column, then the vLAN will be reachable when using Client VPN.
If you wish to change that (i.e you only want VPN to access certain subnets at different MXs across your organization), you will need to add additional rules in Site-to-site outbound firewall at the bottom of the same page.
Finally, if you want the client VPN to only access local subnets, set the Use VPN setting to no.
2 REPLIES 2
Hi @OSPF71,
Thanks, @Mr_IT_Guy. That info helps a lot. The one security appliance we have not replaced with a MX yet is a non Meraki peer which has the subnet(s) with needed resources and is not accessible.
