Client VPN issue on the warm spare mode
Luffy
I set warm spare mode for 2 MX64 device and also set client vpn.
But client vpn didn't connect.
Before setting warm spare mode, client vpn has worked well.
I didn't change any configuration about client vpn.
do you have any experience like this issue ?
Thank you,
2 Replies 2
Did you configure a VIP addressing?  If so, then you'll need to VPN to that IP address.
NolanHerring
How do you have the MX64 connected?
Is your WARM-SPARE status showing Active/Ready?
As @PhilipDAth mentioned, if your doing warm-spare, you have to use the virtual IP configuration mode so that the client can use the vIP for it to function.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
