Client VPN | Type of sign-in info Bug
Justin-F1
Hello:
I've run in to a bug on some of my machines where after I configure the adaptor in Network Connections the type of sign-in username and password are cleared out to show a General authentication method. If I fix this the adaptor's Allowed Protocols are cleared. See below screenshots. This has happened on both Windows 10 and 11 machines. Is there a fix for this?
This seems to be a Windows bug, I suggest you open a ticket with Microsoft or install the latest system updates.
Try configuring it using PowerShell.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
Another option is to try configuring it using rasphone.exe.
