Search instead for
Client VPN Question
Client VPN Question
Hi.
We use Windows 10 with built in VPN client, most of the times it says "connected" but sometimes it just says "connecting" and it seems that  the connection  is not finished. But the VPN is established and works as it should. But it is confusing. Anyone now why the connection not get "connected"?
Re: Client VPN Question
So if it is established and works what is the issue you are experiencing?
Hi.
The issue is that it says connecting and it is spinning like it is waiting to get finish. ..like it is not connected (connection not established) and the users think something is wrong. When everything goes as it should it says directly after authorisation  "connected" but at some rare occasitions it doesn't get "connected"
Ok. thank you for the info
