I am running 14.40.
I am able to connect my windows device and a Mikrotik router. On my Mikrotik if I set the Enc Algorith to just AES then I get the same result on the Meraki with no connection.
This is the event log:
| Non-Meraki / Client VPN negotiation | msg: phase1 negotiation failed. |
| Non-Meraki / Client VPN negotiation | msg: failed to pre-process ph1 packet (side: 1, status 1). |
| Non-Meraki / Client VPN negotiation | msg: failed to get valid proposal. |
| Non-Meraki / Client VPN negotiation | msg: no suitable proposal found. |
This is the packet capture:
20:46:18.436486 IP (tos 0x20, ttl 58, id 0, offset 0, flags [DF], proto UDP (17), length 465)
XXXXXXXXXXXX.500 > XXXXXXXXXXXXX.500: [udp sum ok] isakmp 1.0 msgid 00000000 cookie 2ba7e236e92b62b7->0000000000000000: phase 1 I agg:
(sa: doi=ipsec situation=identity
(p: #0 protoid=isakmp transform=2
(t: #1 id=ike (type=enc value=aes)(type=keylen value=0080)(type=hash value=sha2-256)(type=group desc value=modp1536)(type=auth value=preshared)(type=lifetype value=sec)(type=lifeduration value=7080))
(t: #2 id=ike (type=enc value=aes)(type=keylen value=0080)(type=hash value=sha1)(type=group desc value=modp1536)(type=auth value=preshared)(type=lifetype value=sec)(type=lifeduration value=7080))))
(ke: key len=192 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX)
(nonce: n len=32 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX)
(id: idtype=FQDN protoid=0 port=0 len=5 XXXXX)
(vid: len=8 XXXXXXXXXXXXXXXXX)
(vid: len=16 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX)
