Hi Forum,
I have a customer that has a MX Device behind a NAT Router and the client wants to have the Client VPN feature enabled so we are busy testing this for him using the Meraki Cloud Authentication. We are not able to configure the NAT Router in Bridge mode but we have configured it to forward UDP500 and UDP4500 ports to the MX device.
Before we configured the router to forward UDP 500 and UDP 4500 to the MX Device, we were not able to connect and we were receiving an L2TP Error message on the Windows 10 device. We were also not seeing any events in the Event Log on the MX Device. After forwarding these ports to the MX Device, we are now seeing the events in the Event Log and it seems as if the MX device is completing the connection but we still get a failed connection on the Windows 10 device ("The connection was terminated by the remote compute before it could be completed")
Below is an output of the events in the MX Event Log:
Jun 29 15:57:26 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|5> deleting IKE_SA l2tp-over-ipsec-1[5] between 192.168.8.101[192.168.8.101]...169.159.156.42[10.0.2.15] | |
Jun 29 15:57:26 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|5> closing CHILD_SA net-1{17} with SPIs c3e94349(inbound) (825 bytes) a8824164(outbound) (721 bytes) and TS 192.168.8.101/32[udp/l2f] === 169.159.156.42/32[udp/l2f] | |
Jun 29 15:57:25 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|5> CHILD_SA net-1{17} established with SPIs c3e94349(inbound) a8824164(outbound) and TS 192.168.8.101/32[udp/l2f] === 169.159.156.42/32[udp/l2f] | |
Jun 29 15:57:24 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|5> IKE_SA l2tp-over-ipsec-1[5] established between 192.168.8.101[192.168.8.101]...169.159.156.42[10.0.2.15] | |
Jun 29 15:53:32 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|3> deleting IKE_SA l2tp-over-ipsec-1[3] between 192.168.8.101[192.168.8.101]...169.159.156.42[10.0.2.15] | |
Jun 29 15:53:32 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|3> closing CHILD_SA net-1{16} with SPIs c8d42dee(inbound) (825 bytes) a67b2806(outbound) (721 bytes) and TS 192.168.8.101/32[udp/l2f] === 169.159.156.42/32[udp/l2f] | |
Jun 29 15:53:31 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|3> CHILD_SA net-1{16} established with SPIs c8d42dee(inbound) a67b2806(outbound) and TS 192.168.8.101/32[udp/l2f] === 169.159.156.42/32[udp/l2f] | |
Jun 29 15:53:30 | Non-Meraki / Client VPN negotiation | msg: <l2tp-over-ipsec-1|3> IKE_SA l2tp-over-ipsec-1[3] established between 192.168.8.101[192.168.8.101]...169.159.156.42[10.0.2.15] |
Hi Steven
Try this ; check the PAP on windows !
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration#Windows_10
That worked for me thanks Manjinder.
Not sure if this helps, we had similar issues on Windows 10 Native VPN client. The option I believe we had to set was to make sure all traffic was routed through the VPN (i.e no split tunneling).
Sarvjit
You'll will need to configure the AssumeUDPEncapsulationContextOnSendRule registry entry on Windows 10 machines to allow it to work through NAT.
The easy way - use my online tool to create a PowerShell script to create the VPN connection for it. It'll set all the other tricky stuff so it is most likely to work.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
The other option is to use the MX 16.x code and buy some AnyConnect licences (cheap). This uses TLS, and works automatically in cases like this. After upgrading to 16.x you can test out AnyConnect before buying the licences.
Hi PhilipDAth
I have already configured this option - AssumeUDPEncapsulationContextOnSendRule - and it does not work. I will try your online tool and see if that helps. I will keep you posted on my progress
You wouldn't happen to have a site-site VPN connected as well would you? I am running into the exact same issue that you have. However, I have a site-site VPN connected, and found that when I disable VPN availability for all the VLANs I configured it for, I'm able to make the client VPN connection. Same goes for when I just take the site-site VPN down. I'm probably going to have to call support to help figure out why this is the case.
I have spent significant amount of time investigating this. It is a problem with Windows using VPN with NAT-T.
If you use a MacOS computer, you will be able to connect immediately.
Setting the registry key was a hit or miss for me:
The real solution for me was actually updating Windows to the very latest patch. Along the way Windows themselves must have noticed an issues and one of the patches fixed it.
Make sure to delete the VPN connection and recreate it.
