Client IP conflict
NorthstarCC
Client IP conflict
Meraki MX67 W/MX16.16 Firmware
2 Issues with IP conflicts
Thanks in advance for your help a solution to this
Issue 1 - We have a group of IP's set to be fixed but they are still being assigned thru the DHCP
Issue 2 - Even though the device is assigned a fixed IP it will not stick.  When selecting the device it shows it to be fixed to 192.168.50.53 but it is using 192.168.50.61 (or other number).  Because of this we will have multiple devices using the same IP, but they dont work.
NorthstarCC
Looking like this is the case, WIFI network is also assigning numbers.  Thanks for your help!, if I have any other other updates I'll let you know.
@NorthstarCC,
I'm not sure, what are you trying to do? But have you tried to create Reserved IP ranges? Can you explain it better?
Any chance there is a second DHCP server on the network?
NorthstarCC
