I have a Meraki MX 250 appliance providing DHCP services for endpoint devices.
DNS is proxied to my Windows DNS server. Clients A records are being added but none of them are getting Reverse PTR records.
Prior to having the Meraki I was using Windows DHCP server and this worked.
Any suggestions on how to get Meraki dhcp clients to update the DNS records?
Have you got DHCP (on the Meraki) configured to give out the IP address of your Windows DNS server?
Yes, I have a primary and secondary nameserver configured. The clients are receiving the correct nameservers
Did you find a solution to this? We are experiencing the exact same issue.
I have not found a solution to this and after opening a ticket with Meraki support was told this was not a feature they supported and suggested I put in a wish. I did so, but we all know how long that can take, so we have to find another solution. I'm considering both using IP reservations and then updating my software that does reverse DNS lookups to use IP's instead of names, or moving back to Windows DHCP.
Realising this is an old thread but thought I'd share this. In a nutshell: "Clients with dynamically-set network connections (DHCP clients) will communicate with both the authoritative DNS server and the DHCP server for updating A and PTR records. The DHCP client will communicate with the authoritative DNS server directly for updating its A record, but the DHCP server updates the DNS server with the client’s PTR record on behalf of the DHCP client."
