We have a case that need is to allow Cisco Jabber to be accessible from out side of the network. For that, we’re following the cisco guide.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Cisco-Expresswa...
the idea is to allow Jabber clients register to the on premise cisco call manager.
The optimum scenario (in other firewalls) , is to configure the Edge Expressway server as a DMZ client behind the firewall so that whenever the public IP of the firewalls is requested, it’s forwarded to the DMZ client (the edge expressway server). Unfortunately, the Meraki MX does not have a ready to use DMZ client straight config. So we need to configure port forwarding as per the attached requirements from Cisco.
![MRA Ports.PNG MRA Ports.PNG](https://community.meraki.com/t5/image/serverpage/image-id/1105i0E7D0FE448F02EFE/image-size/large?v=v2&px=999)
When we try to do it, the MX refuse to save and says the source ports and the dist. Ports should be in the same range!
How do you suggest we resolve this issue knowing that the ISP only provided one public IP (used for the MX wan port) with no extra spare public IP to be used.
Appreciate your inputs...
