We are currently rolling out Cisco anyconnect VPN to replace the L2TP VPN my company has been using for years.
One of the last issues we are trying to resolve is getting the vpn profiles to work with the client, when the profile is downloaded from our MX68 appliance it works, and the dropdown box populates with multiple gateways. however the powers that be require the profiles to be set before our users connect to the VPN for the first time.
from the setup documentation (and other forum posts i've found from searching) the xml file should be placed in C:\programdata\cisco\cisco anyconnect secure mobility client\profile
however, after manually placing the .xml file in the profile folder it doesn't populate. I have restarted the services, rebooted, reinstalled, renamed the .xml, remade the file via the profile builder, but nothing I've tried so far has gotten this to work.
I have also tried placing the .xml file into the C:\programdata\cisco\cisco secure client\VPN\Profile without any luck as well.
we are using the default DDNS name that is generated by the MX68 meraki appliance.
meraki firmware is: MX 18.107.2
cisco secure client - Anyconnect VPN version is: 5.0.02075
I've tried this on multiple machines and OS, including Win10 pro, Ent,and win 11 pro.
any insight from the community that can point me in the right direction, as I'm stumped.
##EDIT: to anyone who stumbles on this in the future, the "Profile.xml" is case sensitive. If you attempt to use "profile.xml" for the cisco VPN client, it will not work. @alemabrahao had the solution dead on, this is just a reminder to double check the case of your file.
