Cisco Meraki vs Riverbed comparison
jjfaure
Anyone knows if Cisco Systems has a document comparing Meraki product with Riverbed SD-Wan solution? It needs to be a Cisco document or Cisco url, not a third-party document
Regards,
Juan
2 Replies 2
BrechtSchamp
FWIW I haven't seen a battlecard between Meraki and Riverbed. I checked the Meraki partner portal and Cisco's Salesconnect.
Your best bet is to reach out to your Meraki sales rep or systems engineer. Even if we had such a document it's very likely it would be a confidential document and we would therefore not be allowed to post it here.
I thought Riverbed was more concerned with WAN optimisation (such as redundant data elimination, compression, TCP connection acceleration, etc)?  If so, the most direct comparison is Cisco WAAS.
https://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v413/configuration/guide/cnfg/intr...
Cisco Meraki MX supports SDWAN and Security capabilities.  I don't think the two products overlap that much.
