Hello Meraki Community,
Currently our Anyconnect is setup for user authentication through our NPS RADIUS servers with Duo for 2FA. I want to lock it down so only domain devices can authenticate, so I believe certificate auth would be the best for this. I feel as if we tried every option and keep getting the error " Certificate Validation Failure " when connecting via Secure client. Has anybody successfully set this up? I would love some insight on the proper steps.
Change to using SAML authentication directly against Duo.
https://duo.com/docs/sso-meraki-secure-client
Then configure a Duo policy that requires Device Trust. Tell it to trust all machines that are a member of your AD.
https://duo.com/docs/trusted-endpoints-adds
Roll out Duo Desktop to your machines.
https://duo.com/docs/duo-desktop
This is a far superior option to using RADIUS and NPS.
Hello Phillip,
Thanks for the response but how is this a far superior option?
It uses the Duo native SAML interface for the MFA. You can use push, verified push, TXT, phone call, FIDO2, Windows Hello, etc. Anything you want to allow in your policy.
It allows Duo trust policies to be used. Depending on your plan, you have have it check if antivirus is running, is the machine authorised, is it a member of AD or Intune, etc.
You can enable features Duo like inline password-reset for people's who password has expired. This whole class of calls tot he help desk can be eliminated.
You can use actuall SSO - so once logged in via Duo, the user is automatically logged into every other app using Duo.
Phill,
I appreciate your response. The NPS server needs to stay in place since its handling the group policy within Meraki via Filter-ID with the MX. Can I keep my current setup in place and just implement Duo desktop to check for AD membership?
You can do the same thing by enabling SAML group policy. With this your Idp pushes the meraki group poicy to apply.
No.
Where do you find the SAML attribute Policies ? Is that within Duo or the Meraki Dashboard?
The above screenshot was from Meraki. You'll need to open a support case and request AnyConnect SAML Group policies to be enabled.
In Duo, you tell it to present the extra attribute like below.
