Hi Announcer,
The MX treats client IPsec VPN and AnyConnect VPN subnets as separate pools and routes client traffic accordingly. They can coexist on the same MX, but their subnets should be distinct to avoid conflicts.
In addition, as alemabrahao mentioned, Meraki Dashboard will display an error message:
"There were errors in saving this configuration:
- The client vpn subnet cannot overlap with the AnyConnect VPN subnet."
In this case, I tried to use the same subnet range.
If you have any further questions, please don't hesitate to contact us.
