Can't login to MX locally
dciferit
When I attempt to access the configure or ethernet tab by connecting to the MX locally it throws an error saying incorrect password, you've entered incorrect login credentials... the only thing is I never entered anything. It never gives me the option to sign in. I've tried multiple browsers, I've tried connecting to the device directly, I've tried rebooting, I've tried setting a new password in the dashboard, but nothing gives. Anyone have an idea?
dciferit
Resolved. I didn't try enough browsers and I'm not sure exactly what the cause of the problem is. Firefox worked. Was able to login from phone browser in Chrome as well, but unable to on my computer from Opera, Chrome, or Edge. Big waste of time, thanks Meraki.
5 Replies 5
Try putting the serial number on username and leave the password blank.
What I am saying is I don't get the option to enter anything. No box pops up or login screen. It'll connect to the connection tab, but when I switch to the configure or ethernet tabs, it immediately throws error with no recourse to enter password or username
Have you tried performing a factory reset?
No but I was trying to put that as last ditch effort. Looks like it may be my only option
dciferit
