Can't connect Client VPN from iPhone 12.
AP7
Just browsing
i have tried outside wifi and also tried using phone data i keep gettin following error "The L2TP-VPN server did not respond."
i have followed the guide from here https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration#iOS
here is event log
Non-Meraki / Client VPN negotiation msg: unsupported ID type 5
Non-Meraki / Client VPN negotiation msg: failed to pre-process ph2 packet (side: 1, status: 1).
5 REPLIES 5
Re: Can't connect Client VPN from iPhone 12.
What country are you and who is your carrier?
Can you connect using the same carrier from another device?  It doesn't work via some carriers.
AP7
Just browsing
USA. T-mobile.  on iphone 12 doesnt work. on Android galaxy 9+ works fine with tmobile data
T-mobile only supports IPv6.  You need IPv4 for the client VPN to work.
AP7
Just browsing
on tmobile galaxy 10 it works fine
Condin
I used a proxy (PIA in my case) vpn profile first, then used the meraki profile and it worked.
