Can Meraki pull vpn accounts from two sources at the same time?
Local_goat
So, we're planning on setting up Anyconnect up, but we've currently got our Azure AD VPN set up. I'm trying to find out if Meraki would allow you to have a VPN get pulled from either Anyconnect or AD? We're planning on fully moving over to Anyconnect in chunks, as all at once would be a nightmare for a lot of remote workers. Afraid I haven't seen any documentation online for this issue either, has anyone had experience with Meraki using two sources for their VPN credentials?
You shouldn't have a problem if you enable both at the same time.
@Local_goat,
What do you mean "Meraki using two sources for their VPN credentials"?
Local_goat
Like, within Meraki admin dashboard. I've got IPSec VPN set up, but we're looking to make the swap into Anyconnect, was looking to see if I can have both options available for an end user while we make the transition.
Local_goat
Gotcha, thank you!
