Hi @Quimax
Following is my understanding
Rule 5 Says
"Allow" protocol "TCP" for ["IP Address=x.x.x.75" + port "25"] to destination ["Any IP Address" + port "Any"] - Means a specific IP Address from your LAN can access port 25 service.
Rule 6 Says
"Allow" protocol "TCP" for ["Any IP Address" + port "25"] to destination ["IP Address x.x.x.75" + port "Any"] - Means all IP Addresses from your LAN can use port 25 service for a specific destination.
Rule 7 Says
"Deny" protocol "TCP" for ["Any IP Address" + port "25"] to destination ["Any IP Address" + port "Any"] - Means No IP Address from your LAN can use port 25 service
I believe if you remove Rule 6. You may achieve the desired result.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
