Blocked Sites / Summary Report
My daily summary report used to included blocked websites (top 50) and a summary of each blocked category.  A few weeks ago, that went missing from the report.  The event log still shows blocking is happening but I like the report summary which was emailed daily to tech staff.
How do I bring it back?
Photographer | Marching Band Nerd | Bicyclist
4 REPLIES 4
Re: Blocked Sites / Summary Report
My reports still show that. Odd that yours don't.
Did you customize the report:
Edit: Nvm, you're probably talking about the security report, not the summary report.
It was in the summary report. Below is the screenshot from April 9th.
I think I found it. You actually need to change the filter from "Entire organization" to "Single Network" and then select "Your network - Appliance".
