Block Clients from Connecting to Cisco Anyconnect VPN
Kyojuro
I'm just wondering if there is a way to block or allow only specific clients on to the Meraki Cisco Anyconnect VPN?
Thank you.
2 Replies 2
KarstenI
It all depends on how you define "specific". Whatever it is, it will not be controlled on the MX. If it is pure IP-basd, a device in Front of the MX could handle this with ACLs, for everything else you likely need an integration with your radius server.
If you use either RADIUS or SAML authentication, you could just create a group to say who is allowed to connect.
If you are using local Meraki auth users - I believe you have to authorise them to use the VPN.
