BGP routing over IPSec => VTI Support?
MarcelTempelman
A few quick questions : I noticed that non-meraki VPNs now support BGP routing. In any other case (ASA, routers, etc) I would associate this with Virtual Tunnel Interfaces.
- So is Meraki supporting VTI-based VPNs without calling them VTIs?
- What does this BGP-routing option mean for AutoVPN ; can external routes be advertised over AutoVPN?
It seems very interesting (I've been waiting for some kind of VTi-support for quite some time) but I also have many questions 🙂
with kind regards,
Marcel Tempelman.
KarstenI
I don't know for sure because I don't yet run 19.1. But at least all the options (like the /30 IPsec subnet) speak for a VTI-like implementation.
AlexP
To give hopefully some clarification here:
Routed tunnels are built off generic traffic selectors, so they'll take whatever gets routed to them so long as a matching route exists. This does indeed mean that yes, routing between Non-Meraki VPNs and AutoVPN is possible now, in addition to being able to full-tunnel traffic from a Non-Meraki site to a Meraki one.
Bucket
Is it a VTI or not? I don't see how it would work without the other end being configured as VTI.
AlexP
MX firmware is Linux-based, so it's not called a "VTI" on our end, but functionally, it should be mostly the same: it sends traffic to an arbitrarily defined interface that maps to a given VPN peer internally, and it does so based on what route information we've learned from said peer.
