BGP configuration between Cisco router and MX
FG
Hello all :
I need some helps to configure BGP between the Cisco router and MX, here is the diagram :
MX one arm connected to the Cisco Core switch and core switch also connects to Cisco router .
I need to set up eBGP between MX and router , however, the BGP is stuck in "Active"
Here is router configure :
router bgp 64984
bgp log-neighbor-changes
neighbor 10.5.3.14 remote-as 65533
neighbor 10.5.3.14 disable-connected-check
neighbor 10.5.3.14 update-source GigabitEthernet0/0/1
neighbor 10.5.3.14 soft-reconfiguration inbound
interface GigabitEthernet0/0/1
ip address 10.5.6.1 255.255.255.248
Here is MX configure
From the router , I am able to ping MX
ping 10.5.3.14 source gigabitEthernet 0/0/1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.5.3.14, timeout is 2 seconds:
Packet sent with a source address of 10.5.6.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
From MX , I am able to ping router as well
But the BGP is in "Active"
sh ip bgp su
BGP router identifier 10.1.3.6, local AS number 64984
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.5.3.14 4 65533 0 0 1 0 0 never Active
10 Replies 10
Happiman
Please configure multihop on your CORE RT.
Since eBGP always assumes the neighbor router  is only one hop away, TTL of one.
https://networklessons.com/bgp/ebgp-multihop
FG
still not works ,
here is my updated config:
router bgp 64984
neighbor 10.5.3.14 ebgp-multihop 3
neighbor 10.5.3.14 version 4
10.5.3.14 4 65533 0 0 1 0 0 never Idle
ping 10.5.3.14
Happiman
can you capture packets on the BGP Interface? I am curious how MX handles eBGP with a multihop.
Happiman
and please run debug ip bgp and debug ip tcp transactions as well.
FG
This is capture from MX
--- Start Of Stream ---
tcpdump: listening on wan0_sniff, link-type EN10MB (Ethernet), capture size 262144 bytes
21:18:39.008602 IP (tos 0x0, ttl 200, id 1491, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1491, length 64
21:18:39.015503 IP (tos 0x0, ttl 254, id 1491, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1491, length 64
21:18:42.012602 IP (tos 0x0, ttl 200, id 1492, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1492, length 64
21:18:42.015627 IP (tos 0x0, ttl 254, id 1492, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1492, length 64
21:18:45.016602 IP (tos 0x0, ttl 200, id 1493, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1493, length 64
21:18:45.019585 IP (tos 0x0, ttl 254, id 1493, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1493, length 64
21:18:45.527085 IP (tos 0xc0, ttl 2, id 28770, offset 0, flags [DF], proto TCP (6), length 44)
10.5.6.1.46450 > 10.5.3.14.179: Flags [S], cksum 0x343b (correct), seq 3531898408, win 16384, options [mss 1460], length 0
21:18:45.527124 IP (tos 0xc0, ttl 255, id 0, offset 0, flags [DF], proto TCP (6), length 44)
10.5.3.14.179 > 10.5.6.1.46450: Flags [S.], cksum 0x2f57 (correct), seq 1159302569, ack 3531898409, win 29200, options [mss 1460], length 0
21:18:45.527507 IP (tos 0xc0, ttl 2, id 28771, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.46450 > 10.5.3.14.179: Flags [.], cksum 0x7924 (correct), seq 1, ack 1, win 16384, length 0
21:18:45.527574 IP (tos 0xc0, ttl 255, id 48558, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.46450: Flags [F.], cksum 0x4713 (correct), seq 1, ack 1, win 29200, length 0
21:18:45.527779 IP (tos 0xc0, ttl 2, id 28772, offset 0, flags [DF], proto TCP (6), length 97)
10.5.6.1.46450 > 10.5.3.14.179: Flags [P.], cksum 0x5a00 (correct), seq 1:58, ack 1, win 16384, length 57: BGP
Open Message (1), length: 57
Version 4, my AS 64984, Holdtime 180s, ID 10.1.3.6
Optional parameters, length: 28
Option Capabilities Advertisement (2), length: 6
Multiprotocol Extensions (1), length: 4
AFI IPv4 (1), SAFI Unicast (1)
0x0000: 0001 0001
Option Capabilities Advertisement (2), length: 2
Route Refresh (Cisco) (128), length: 0
Route Refresh (2), length: 0
Enhanced Route Refresh (70), length: 0
no decoder for Capability 70
32-Bit AS Number (65), length: 4
4 Byte AS 64984
0x0000: 0000 fdd8
21:18:45.527798 IP (tos 0xc0, ttl 64, id 19177, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.46450: Flags [R], cksum 0x09df (correct), seq 1159302570, win 0, length 0
21:18:45.527892 IP (tos 0xc0, ttl 2, id 28773, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.46450 > 10.5.3.14.179: Flags [.], cksum 0x78ea (correct), seq 58, ack 2, win 16384, length 0
21:18:45.527903 IP (tos 0xc0, ttl 64, id 19178, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.46450: Flags [R], cksum 0x09de (correct), seq 1159302571, win 0, length 0
21:18:45.528233 IP (tos 0xc0, ttl 2, id 28774, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.46450 > 10.5.3.14.179: Flags [FP.], cksum 0x78e1 (correct), seq 58, ack 2, win 16384, length 0
21:18:45.528245 IP (tos 0xc0, ttl 64, id 19179, offset 0, flags [DF], proto TCP (6), length 40)
21:18:45.528339 IP (tos 0xc0, ttl 2, id 28775, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.46450 > 10.5.3.14.179: Flags [.], cksum 0x78e9 (correct), seq 59, ack 2, win 16384, length 0
21:18:45.528349 IP (tos 0xc0, ttl 64, id 19180, offset 0, flags [DF], proto TCP (6), length 40)
21:18:48.016602 IP (tos 0x0, ttl 200, id 1494, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1494, length 64
21:18:48.019635 IP (tos 0x0, ttl 254, id 1494, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1494, length 64
21:18:51.020603 IP (tos 0x0, ttl 200, id 1495, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1495, length 64
21:18:51.023513 IP (tos 0x0, ttl 254, id 1495, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1495, length 64
21:18:54.024603 IP (tos 0x0, ttl 200, id 1496, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1496, length 64
21:18:54.027548 IP (tos 0x0, ttl 254, id 1496, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1496, length 64
21:18:57.024603 IP (tos 0x0, ttl 200, id 1497, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1497, length 64
21:18:57.031496 IP (tos 0x0, ttl 254, id 1497, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1497, length 64
21:18:59.864853 IP (tos 0xc0, ttl 2, id 52585, offset 0, flags [DF], proto TCP (6), length 44)
10.5.6.1.30784 > 10.5.3.14.179: Flags [S], cksum 0x9b58 (correct), seq 2819194552, win 16384, options [mss 1460], length 0
21:18:59.864918 IP (tos 0xc0, ttl 255, id 0, offset 0, flags [DF], proto TCP (6), length 44)
10.5.3.14.179 > 10.5.6.1.30784: Flags [S.], cksum 0x5b27 (correct), seq 3235663155, ack 2819194553, win 29200, options [mss 1460], length 0
21:18:59.865310 IP (tos 0xc0, ttl 2, id 52586, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.30784 > 10.5.3.14.179: Flags [.], cksum 0xa4f4 (correct), seq 1, ack 1, win 16384, length 0
21:18:59.865399 IP (tos 0xc0, ttl 255, id 29488, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.30784: Flags [F.], cksum 0x72e3 (correct), seq 1, ack 1, win 29200, length 0
21:18:59.865626 IP (tos 0xc0, ttl 2, id 52587, offset 0, flags [DF], proto TCP (6), length 97)
10.5.6.1.30784 > 10.5.3.14.179: Flags [P.], cksum 0x85d0 (correct), seq 1:58, ack 1, win 16384, length 57: BGP
0x0000: 0001 0001
4 Byte AS 64984
0x0000: 0000 fdd8
21:18:59.865668 IP (tos 0xc0, ttl 64, id 20706, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.30784: Flags [R], cksum 0x0bc4 (correct), seq 3235663156, win 0, length 0
21:18:59.865865 IP (tos 0xc0, ttl 2, id 52588, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.30784 > 10.5.3.14.179: Flags [.], cksum 0xa4ba (correct), seq 58, ack 2, win 16384, length 0
21:18:59.865893 IP (tos 0xc0, ttl 64, id 20707, offset 0, flags [DF], proto TCP (6), length 40)
10.5.3.14.179 > 10.5.6.1.30784: Flags [R], cksum 0x0bc3 (correct), seq 3235663157, win 0, length 0
21:18:59.866069 IP (tos 0xc0, ttl 2, id 52589, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.30784 > 10.5.3.14.179: Flags [FP.], cksum 0xa4b1 (correct), seq 58, ack 2, win 16384, length 0
21:18:59.866078 IP (tos 0xc0, ttl 64, id 20708, offset 0, flags [DF], proto TCP (6), length 40)
21:18:59.866633 IP (tos 0xc0, ttl 2, id 52590, offset 0, flags [DF], proto TCP (6), length 40)
10.5.6.1.30784 > 10.5.3.14.179: Flags [.], cksum 0xa4b9 (correct), seq 59, ack 2, win 16384, length 0
21:18:59.866717 IP (tos 0xc0, ttl 64, id 20709, offset 0, flags [DF], proto TCP (6), length 40)
21:19:00.028603 IP (tos 0x0, ttl 200, id 1498, offset 0, flags [none], proto ICMP (1), length 84)
10.5.3.14 > 10.5.6.1: ICMP echo request, id 39906, seq 1498, length 64
21:19:00.031605 IP (tos 0x0, ttl 254, id 1498, offset 0, flags [none], proto ICMP (1), length 84)
10.5.6.1 > 10.5.3.14: ICMP echo reply, id 39906, seq 1498, length 64
--- End Of Stream ---
FG
ok, all
I created a case, and support tech has to change multihop for MX since the router is not directly connected.
Now BGP is up
Meraki MX gained eBGEP support in 15.10.  Are you running 15.10 or newer?
FG
I am on 14.39 , I am going to upgrade and test again
FG
now, MX is running on 15.13 , but same issue .
I assume you can't see any extra configurable items about eBGP in the dashboard since the upgrade?
Open a ticket with Cisco Meraki support.  Perhaps it is a feature (eBGP) which they need to configure.
