Azure S2s tunnel no traffic
zazk6489
hello, i was able to create a s2s tunnel with azure using the meraki and azure documentation, the tunnel is online , connection established, but i cannot ping any vm in my azure frontend subnet, or from azure to my on-premise network or even the gateway of my local lan participating in the vpn tunnel,
created a route on my azure , associated the route to my frontend subnet, destination cidr is my local vlan, next hope is azure virtual network gateway, What I am missing? thanks
5 Replies 5
Is there any ACL configured on Azure?
Do you have any firewall configured on your servers?
zazk6489
No ACL on Azure, disabled defender firewall on azure VM,
If you jump on a machine in Azure and ping something on-premise and do a packet capture on your MX - do you see the traffic?  If not, something is wrong on the Azure side.  If yes, something is wrong on the on-premise side.
pmhaske
Hello!
If you need any assistance with packet captures and verifying tunnel connectivity, I recommend opening a case with Meraki Support so an NSE can also help with the investigation.
zazk6489
Overlook in configuration, it is easy to miss which vnet to put in private subnet field on Meraki side, it is the fronend subnet where azure resources are
