AutoVPN issues with WAN 2
P4ck3ts
hi,
WAN 1 is set to primary uplink with load balancing disabled. AutoVPN works fine.
When I add WAN 2 into the mix, RDP connections go down. Active-Active AutoVPN is set to disabled by the way. But the issue still persists.
any help appreciated.
thanks
5 Replies 5
RaphaelL
What MX model  ?
What MX version ?
P4ck3ts
mx100 running 18.107.
to add WAN 2 is under NAT.
Is it 18.107.4, or the unpatched version
If you try the NATed connection on its own what do you get?
P4ck3ts
i will try on a non workday as I can't have this site down. I think both WANs need to be connected to the VPN registry. WAN 2 is under CGNAT and I think its blocking the UDP hole punch
LindseyG
There's a known issue with MX's on v18.107 that in certain scenarios when you have a HA pair, if you make changes, it causes services to restart, including VPN's.
There is an internal case at Meraki and my case is linked to it.
The details i got told were:
Certain changes have been seen to cause services to restart, causing VPN tunnels to drop and reform when running an HA pair of MX’s on firmware version 18+:
  • Firewall rules changes
  • DHCP scope changes
  • Layer3 changes to VPN-enabled subnets/routes
  • Bringing up disconnected WAN2/Cellular interfaces from the “disconnected” status
  • Enabling or disabling content filtering
I'd raise this with Meraki so it gets linked to their internal case.
