Hello team,
I have a setup with two uplinks (WAN1 and WAN2), from 2 different service providers, connected to an MX250 (18.211.6) appliance. Both ISP routers are connected to a switch and through different VLANs they get to MX fiber ports.
The setup is as Load Balancing 50/50 (the two lines are both 1Gbps) with no relevant flow preferences.
trying a failover test, powering off one router at the time, I can see that failover from WAN1 (primary) to WAN2 takes about 20 to 30 pings (which is a lot) whereas failover from WAN2 to WAN1 is extermely fast (1 or 2 pings lost at most).
is this expected? Does it take more for the MX to "give up" on the Primary WAN even in symmetrical load balancing? Or am I experiencing some kind of issue that needs to be adressed?
thanks
F.
