We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
Ask: How to config between 2 appliance can ping and access by diagram attachments
Thank You
Solved! Go to solution.
As long as the Gateway LANs are connected to the [same] Internet you can just enable AutoVPN.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_autovpn.pdf
Thanks for the reply
