Asa for anyconnect behind MX Firewall
PRISMI
Hi guys,
anyone know where i can find technical documentation to install ed of course configure  one ASA behind one MX Firewall ?
I need to use ASA only for anyconnect client .
The MX firewall need to be used as firewall and site to site vpn with other MX .
Thanks a lot
2 Replies 2
CptnCrnch
Basically, you allowing access from the outside to your ASA (TCP and UDP port 443) and set up AnyConnect on ASA. What kind of documentation do you need with this?
JManship89
I’d consider changing the port your ASA used for client VPN in case you use 443 for something else.
