Are Meraki devices vulnerable to the TCP SACK Kernel Panic DOS?
Accepted Solutions
Re: Are Meraki devices vulnerable to the TCP SACK Kernel Panic DOS?
The description of the CVE says that you have to establish a connection to a device to exploit this. The MX simply routing traffic through it would not be affected.
3 REPLIES 3
Interesting... I'll obviously defer to Meraki to answer this, but thinking out loud, and assuming I understand the description of the problem, you would first need to establish a TCP connection to a device before you could trigger it. I haven't port scanned a Meraki device for a while, but IIRC your only option here would be the local status page. Turning that off should mitigate this, unless there's other open TCP ports...
Thanks @jdsilva!
Since HTTP runs over TCP, and our MX250 routes traffic from the public Internet, it would be reassuring if Meraki would confirm we can't be DOS'd with TCP SACK. 🙂
