Anyone having Client VPN issues with MacOS
Dear Friends,
First my apologies for being a little silent on my most favourite community group of all time, fortunately, I have has lots of post-C19 lockdown small job's that have kept me busy for the last few weeks - small revenue but better than nothing 🙂
I have a medium size SME client with a full stack Meraki install (MX64 HA pair, MS320,MS220 & MR33's) and a mix of W10 and Mac client VPN users, normal the Mac Users are TOTALY trouble-free (and take almost no time to set-up, my record is 97 seconds), whereas W10 users can take anywhere between 15 mins and a day ...........
However over the last few days, I have been getting a few calls from the Mac users saying that they are having issues connecting, I have not done any diagnostics yet and it does appear inconsistent.
I was just wondering if anyone else has noticed/seen this
Regards
Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
4 REPLIES 4
Re: Anyone having Client VPN issues with MacOS
Just for info,...
I' m no expert, but I use ClientVPN almost daily (standard setup) with my MacBook Pro (macOS Catalina) and my iPad without any problems. ClientVPN setup is on an MX65, no more than 2 client logged in simultaneously.
LD
Thanks for the comment and response
BR
-Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
Use my Windows 10 client VPN wizard and you'll get those Windows 10 users going quickly every time.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
thanks for this
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
