Thanks for the links, but not really what I am looking for here.
It might be that I need to redo something here to get MFA for Azure to work.
The flow today is the following:
ASA - Cisco ISE - Azure MFA
- The radius request is sent to my Cisco ISE, that handles the request to our Azure MFA setup.
The condition here in ISE and my policy looks like this:
Here use the Cisco-VPN3000/ASA/PIX7x-Tunnel-Group that the ASA sends to ISE to trig the Azure MFA function, but what is Meraki sending??
I need to trig the same function inside ISE here. but what is Meraki using here??
So it might be more the ISE condition I need help with, because Meraki is very simple here on what you can setup in the dashboard. 🙂
So is hoping somebody else has setup Anyconnect with ISE and some MFA. 😄
Frank
	Frank Osberg | Domain Architect @ Solar A/S
LinkedIn -
TwitterFound this helpful? Give me some Kudos! Much Thanks
