I'm wondering if anyone has set up their Meraki MX with AnyConnect to authenticate against Azure AD and if so how did you do it?
Solved! Go to solution.
I could be wrong but I think the link above is for MS Azure SAML auth for dashboard.
This seems to be one specifically for anyconnect:
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/AnyConnect_Azure_AD_SA...
I've done it as a PoC. You have to tell Support to enable SAML for AnyConnect and then just follow the guide:
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Configuring_SAML_S...
We didn't implement it later because with RADIUS the ISE was able to easily return Group-Policies for differentiated user-access.
Damn, wrong link ... Yes, luckily at least one other paid attention ... 🙂
I assume the url for the AnyConnect server is the same as on the AnyConnect page of the MX appliance?
Correct
I swear this is the neatest **** when it works the way it is supposed to. 😄
