We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I'm wondering if anyone has set up their Meraki MX with AnyConnect to authenticate against Azure AD and if so how did you do it?
Solved! Go to solution.
I could be wrong but I think the link above is for MS Azure SAML auth for dashboard.
This seems to be one specifically for anyconnect:
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/AnyConnect_Azure_AD_SA...
I've done it as a PoC. You have to tell Support to enable SAML for AnyConnect and then just follow the guide:
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Configuring_SAML_S...
We didn't implement it later because with RADIUS the ISE was able to easily return Group-Policies for differentiated user-access.
Damn, wrong link ... Yes, luckily at least one other paid attention ... 🙂
I assume the url for the AnyConnect server is the same as on the AnyConnect page of the MX appliance?
Correct
I swear this is the neatest **** when it works the way it is supposed to. 😄
