AnyConnect VPN Connection on MX Terminations
tman
Is there a way to terminate all Anyconnect VPN sessions on a nightly basis say 3:00 am. I know you can configure the session timeout but not every one connects at the same time.
Meraki currently does not provide a built-in way to automatically terminate all AnyConnect VPN sessions on a scheduled basis via the Dashboard or API.
In this case, I suggest you make a feature request.
If you are using AnyConnect, would the session timeout achieve what you want?
If you set it to something like 12 hours, it would guarantee that the session would be terminated after that much time had elapsed.  It wouldn't happen at a specific time, like 3 am, but it would prevent people from remaining connected 24 hours.
jimmyt234
You could leverage the API to disable the AnyConnect service and re-enable it every night at 3am 😁
Pavithran_Che
One more way to do it, create a group policy for client machine to disconnect the AnyConnect VPN during the timeframe.
