Any Connect Auth using Radius
chesterweirdo
Has anyone managed to get Any Connect on the MX to auth using Radius?
We are trying to use Free radius which we use for our Wifi without issue but cannot get it to work with Any connect.
Any pointers would be great. Support say they can not help
we see
(214) ERROR: No Auth-Type found: rejecting the user via Post-Auth-Type = Reject
(214) Failed to authenticate the user
(214) Login incorrect (No Auth-Type found: rejecting the user via Post-Auth-Type = Reject):
in our radius logs
2 REPLIES 2
Can you get a debug of the actual RADIUS attributes recieved?  That is likely to make the error more evident.
KarstenI
Did you manipulate the Auth-type settings in your Freeradius-config? I general you shouldn't as the default matches nearly everything. The MX uses the plaintext-authentication-method PAP_ASCII, if you want or need to configure your Freeradius for that, make sure that this method is enabled.
