We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hi everyone!
It is possible Meraki could have any kind of issue with ISP Anti-DDoS service?
Anyone experienced slowness using this kind of service?
NETSCOUT | Arbor Sightline
Thanks.
Solved! Go to solution.
Yes.
But are you sure that your symptoms are related to a NDDOS solution ?
What kind of traffic do you suspect is getting dropped ?
No, I'm not sure.
Just for exclusion... I tested everything else.
Changing the MXs, cables, configs, disabling security features, etc.
Clearly it is some issue between Meraki and this link, and this link has Anti-DDos,
@RaphaelL thank you!ISP answered:
"Analyzing the contracted DDoS service, there has been no active mitigation for your environment since the service was activated.
Blocking by the DDoS tool only occurs when there is a mitigation in progress, which is only carried out after prior authorization."
