Final Update from the ticket I submitted:
Thank you for reaching out to Cisco Meraki Technical support.
From what I understand from your question, that is correct that if the IP addresses from the ISPs change you do need to update them on the Meraki Manually.
Had this been Meraki auto VPN, the changes in the IPs on the tunnel would've happened automatically.
If you want to allow this tunnel connection for Meraki devices to connect to the VPN without the "head end", you can put the MXs in the passthrough mode.
This will allow the MXs to still retain its content filtering and firewall rule capabilities without actually performing any NAT on its own.
With this setting, you can even put a sonicwall firewall ahead of the MX for the VPN purposes
Thank you
