Allow list URL patterns
guitb
Within a group policy's 'Allow list URL patterns', do the following configurations have the same effect?
abcd.com
*.abcd.com
My goal is to allow all domains and subdomains of 'abcd.com'.
ChrisJ2
Hi all,
This can be confusing, as the behavior differs from FQDN usage in L3 firewall rules,
The allow list URL Patterns does not support the use of the Asterix "*" as a wildcard within the URL.
  • The " * " (asterisk) symbol when used as part of a URL or in line with a URL is simply a regular asterisk symbol and is interpreted as part of the URL, NOT as a wildcard
  • Note that this isvery rarely useful, except in URLs that actually require asterisk symbols, such as https://web.archive.org/web/*/meraki.com
the "*" can only be used as a 'catch-all' wildcard, allowing or blocking everything.
entering abcd.com into the Allowed URL list, will allow all subdomains of abcd.com, and this would be the recommended usage.
Please refer to the documentation below for more information:
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Content_Filtering#Using_...
7 Replies 7
No, the asterisk will allow everything that comes before the dot, the URL without the asterisk will not.
For example, if you allow abcd.com and there is an ecommerce.abcd.com, you will not be able to access that URL.
guitb
Thank you @alemabrahao  for the clarification.
Would you happen to know of any Meraki documentation that details this, so I can share it internally?
RaphaelL
I was under the impression that the behavior was similar to FQDN support in L3 firewall rules. Which it might not https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Firewall_Settings#FQDN_Support
  1. FQDN rules imply a wildcard when no subdomain is used by prepending a * to the domain.tld. This wildcard is not shown on the Dashboard but is visible in syslog messages if syslog is configured for a network. For example, a rule to permit "yahoo.com" would permit any subdomain under yahoo.com such as mail.yahoo.com. Permitting "mail.yahoo.com" in the rule would only permit mail.yahoo.com and not the TLD or other subdomain of yahoo.com.
ChrisJ2
Hi all,
RaphaelL
Hi ,
You are saying it differs , but it doesn't differs in the way that either in L3 firewall or Allowed URLs : abcd.com or *.abcd.com is equal.
ChrisJ2
Hi
Thank you for your reply.
In Allowed URLs, abcd.com will allow all subdomains of abcd.com , whereas "*abcd.com" will only allow the URL "*.abc.com" which is unlikely to be useful.
  • The " * " (asterisk) symbol when used as part of a URL or in line with a URL is simply a regular asterisk symbol and is interpreted as part of the URL, NOT as a wildcard.
