Allow Spotify only on guest wifi and not corporate wifi
Announcer
I want only devices on the guest wifi to access Spotify because this network is throttled.  I do not want Spotify open on the corporate wifi or corporate network as it's not throttled.  How would I do this?  I have one guest wifi, one corporate wifi, and corporate LAN
Thanks!
5 Replies 5
You can deny it on your Corp SSID and on you Guest SSID you can let it allowed. Very simple.
Oh, for your wired network you have to limit it via firewall, I don't know which firewall you have, but you have to work on it.
If it is on the MX, just create a group policy and apply it to the VLAN.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
Announcer
Thanks, the corp ssid makes sense, yes.  If I create a group policy for the corporate VLAN, will it stop processing the firewall rules from the MX?
Yes, for the L3 and L7 rules will be used what you configured on the group policy.
