Addressing/VLAN
themru
Addressing/VLAN
I have created two VLAN's from Addressing and VLAN's.
Network 1===> 10.10.100.0/24
Network 2===> 171.25.30.25
Scenario 1
I believe from Layer 3 Firewall I can deny traffic from those two V LAN's, however when someone connects from VPN, I will need to block the traffic from outbound rules.
Is this a correct scenario.
Scenario 2
I will add some more Meraki's device to this organisation, I want to restrict view only to some of the Meraki's.  Meaning user will only be able to see only some meraki's appliance and not some.
Is this feasible?
2 Replies 2
KarstenI
Scenario 1: Yes, the L3 rules are only for internet- and inter-VLAN traffic. For AUtoVPN, you have to configure the outbound filter under S2S-VPN. For extranet-VPN you can't filter the traffic on the MX. You need to use a different firewall for your extranet VPNs.
Scenario 2: There is role-based access-control to assign differentiated access to your networks. You have to decide if these fulfilled your needs. At least you can restrict on a per-network level.
