Access MX local Mgmt page through MPLS VPN remote site.
Ahmed_Fathy
Can I access MX local Mgmt page remotely through MPLS connected on MX LAN ports (ping works fine) or should the endpoint (ex: laptop, PC.....) used for Mgmt be directly connected and in the same LAN...….. or as long as there is a reachability to MX then i can access its local web Mgmt page? and if not,.... is there any workaround ?
note: MPLS is reachable to MX through static route.
Ryan_Miles
Do you have remote device status pages enabled? If so, you should be able to reach the local status webpage via any reachable/route-able LAN IP on your MX.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
1 Reply 1
Ryan_Miles
