AD integration with meraki dashboard for management of users email ID's database
Prashant_India
We have a case like we wanted to manage huge user ID's on meraki dashboard .
Currently we are using local credentials for accessing meraki dashboard .
Can we provide meraki dashboard access by using AD credentials for effectively unlocking/deletion user ID's etc ?
How we can achieve this ?
1 Reply 1
Nash
To confirm:
You need to maintain a large Meraki cloud credential user database.
You want to use AD credentials to provide Meraki dashboard access for managing those.
Solution:
Setup SAML SSO: https://documentation.meraki.com/zGeneral_Administration/Managing_Dashboard_Access/Configuring_SAML_...
The linked document includes instructions for setting it up with several supported methods. There's also Azure support.
If you want someone to only be able to manage users, create a role with the Guest Ambassador permission. You'll have to set this up on a per-network basis.
