802.1x Fail Over Scenarios - Meraki ? vs IOS IBNS
AhmedJawad
Hi All
  First Time on Meraki Community. we are upgrading our LAN to all Meraki. the previous Cisco 2960x and other switches is configured with 802.1x and IBNS2 , IBNS2 is covering all the failures scenarios
Is there is anything similar in Meraki? any design guide I can read regarding that?
1 Reply 1
GIdenJoe
Nope..
You don't have the flexibility to design your own event based system to finetune the authentication behavior of a Meraki switch.  Catalyst switches are way more feature rich than MS switches but the difficulty/complexity to configure also grows with the featureset.
The behavior which is fixed on MS switches is described here:
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)
